12 years agoCygheap issue with Nios II tools
Hello everyone, I'm facing an error from time to time when I execute nios2-xxx tools or when I start debugging in Nios II Eclipse. -> I'm getting a cygwin error as follows:
0 ...
10 years agoHi,
This error is still reproducible with QuartusII 14.0. nios2-elf-g++ -T'.../software/Fw_bsp_app/linker.x' -msys-crt0='.../software/Fw_bsp_app/obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L.../software/liboplkcnapp-hostif -L.../software/Fw_bsp_app -Wl,-Map=Fw_host_app.map -O2 -g -Wall -mhw-div -mhw-mul -mno-hw-mulx -Wall -Wextra -pedantic -std=c99 -DNDEBUG -DCONFIG_CN -DALT_TCIMEM_SIZE=4096 -o Fw_host_app.elf obj/default//.../software/app.o obj/default//.../software/canbus.o obj/default//.../software/event.o obj/default/main.o obj/default/arp.o obj/default/gpio-nios2.o -loplkcnapp-hostif -lm nios2-elf-insert Fw_host_app.elf --thread_model hal --cpu_name host_0_cpu_1 --qsys true --simulation_enabled false --id xxxxx --sidp xxxxx --timestamp 1465982303 --stderr_dev host_0_jtag_uart_0 --stdin_dev host_0_jtag_uart_0 --stdout_dev host_0_jtag_uart_0 --sopc_system_name cnDualHostifGpio --quartus_project_dir "board" --jdi .../cn-dual-hostif-gpio.jdi --sopcinfo .../cnDualHostifGpio.sopcinfo 0 [main] perl (6448) C:\altera\14.0\quartus\bin64\cygwin\bin\perl.exe: *** fatal error - cygheap base mismatch detected - 0x612708D0/0xBA08D0. This problem is probably due to using incompatible versions of the cygwin DLL. Search for cygwin1.dll using the Windows Start->Find/Search facility and delete all but the most recent version. The most recent version *should* reside in x:\cygwin\bin, where 'x' is the drive on which you have installed the cygwin distribution. Rebooting is also suggested if you are unable to find another cygwin DLL. /cygdrive/c/altera/14.0/nios2eds/bin/sh_pl.sh: line 2: 6916 Segmentation fault PERL5LIB="$(cd "${SOPC_KIT_NIOS2}" 2>/dev/null && pwd 2>/dev/null)/bin" perl "${SH_PL:-$0.pl}" $@ Best regards, Romain
