12 years agoCygheap issue with Nios II tools
Hello everyone, I'm facing an error from time to time when I execute nios2-xxx tools or when I start debugging in Nios II Eclipse. -> I'm getting a cygwin error as follows:
0 ...
12 years ago --- Quote Start --- Hello everyone, I'm facing an error from time to time when I execute nios2-xxx tools or when I start debugging in Nios II Eclipse. -> I'm getting a cygwin error as follows:
0 perl (5284) C:\altera\13.0sp1\quartus\bin\cygwin\bin\perl.exe: *** fatal error - cygheap base mismatch detected - 0x612708D0/0x8208D0.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version. The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution. Rebooting is also suggested if you
are unable to find another cygwin DLL.
/cygdrive/c/altera/13.0sp1/nios2eds/bin/sh_pl.sh: line 2: 5372 Segmentation fault PERL5LIB=`cygpath -u "$SOPC_KIT_NIOS2/bin"` perl "${SH_PL:-$0.pl}" $@
I've already found some posts in the net about this issue related to Win7 64bit, but didn't try them yet since I don't want to ruin my Quartus installation. Btw, I have no other cygwin installation on my system. Is there any solution to avoid that error and also avoid rebooting the PC? Best regards --- Quote End --- I have it too... If someone has a solution for it....
