9 years agoCyclone V SOC FPGA: gcc not found with gcc-linaro-arm-linux-gnueabihf installed
I have followed the instruction here to setup toolchain https://rocketboards.org/foswiki/documentation/gitgettingstarted as below:
$ cd ~
$ wget https://launchpad.net/linaro-toolchain-binaries/trunk/2012.11/+download/gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux.tar.bz2
$ tar xjf gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux.tar.bz2
$ export CROSS_COMPILE=~/gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux/bin/arm-linux-gnueabihf-
i have check the env var been set correctly with the CROSS_COMPILE. However I still not able to compile any file. It still always prompt out this error for everything I tried to install
/bin/sh: gcc: command not foundmake: *** Error 127
make: *** Error 2
Anyone encounter this before? Is there any solution for this? Thanks.2 Replies
Issue solved....
Can you tell how you were able to resolve this?
