8 years agoCyclone V SoC doubt
Hi, I will have to program a RISC-V processor and I wanted to know if it's possible to access to ARM Cortex-A9 L1 and L2 caches or if I will have to use FPGA memory as cache. Also, I wanted ...
8 years agoEricv,
In that case I will have to use RAM memory as an L1 and L2 caches for my project because ARM Cortex-A9 can't be programmed in VHDL. As I understand having a SoC FPGA allow us to use a high computation algorithm in the processor while the FPGA is doing some data processing or controlling real time systems with a high bandwidth between both, am I wrong? Thank you, Joel
