8 years agoCyclone V SoC Devkit problems compiling Angstrom kernel
Hello to everyone. I’m a doctorate of the department of Electronics Engineering of the University of Modena and Reggio Emilia (Italy) and I’m working in collaboration with a company in Bologna...
8 years ago2. Creating SD Card Image Using Rebuilt Binaries: in this case the guide is very laconic, as it explains that: this section presents how to build the sd card image for arria v from the rebuilt binaries. this is very similar with creating using prebuilt binaries, except using the files from where they are built. the default locations are used.
This is followed by the list of locations. Now, I try to recover the files required by the list following the locations shown; Obviously, lacking the file u-boot-cyclone5.img, I have tried to rename the file u-boot.img that I have found in the folder created after the kernel compilation. So, I have written the following set of instructions: cd ~ mkdir linux-socfpga-gsrd-17.1-cv-bin cd ~/linux-socfpga-gsrd-17.1-cv-bin mkdir rootfs cp /home/davide/angstrom-build/deploy/glibc/images/cyclone5/gsrd-console-image-cyclone5.tar.xz /home/davide/linux-socfpga-gsrd-17.1-cv-bin xz -d gsrd-console-image-cyclone5.tar.xz sudo tar xf gsrd-console-image-cyclone5.tar -C rootfs cp /home/davide/angstrom-build/deploy/glibc/images/cyclone5/zImage /home/davide/linux-socfpga-gsrd-17.1-cv-bin cp /home/davide/SDcard/u-boot-cyclone5.img /home/davide/linux-socfpga-gsrd-17.1-cv-bin# cd /home/davide/angstrom-build/deploy/glibc/images/cyclone5# mkdir prova# cp /home/davide/angstrom-build/deploy/glibc/images/cyclone5/gsrd-console-image-cyclone5.tar.gz /home/davide/angstrom-build/deploy/glibc/images/cyclone5/prova# cd /home/davide/angstrom-build/deploy/glibc/images/cyclone5/prova# gunzip gsrd-console-image-cyclone5.tar.gz# cp /home/davide/angstrom-build/deploy/glibc/images/cyclone5/prova/gsrd-console-image-cyclone5.tar /home/davide/linux-socfpga-gsrd-17.1-cv-bin cp /home/davide/cv_soc_devkit_ghrd/soc_system.rbf /home/davide/linux-socfpga-gsrd-17.1-cv-bin cp /home/davide/cv_soc_devkit_ghrd/software/spl_bsp/preloader-mkpimage.bin /home/davide/linux-socfpga-gsrd-17.1-cv-bin cp /home/davide/cv_soc_devkit_ghrd/socfpga.dtb /home/davide/linux-socfpga-gsrd-17.1-cv-bin cp /home/davide/u-boot.scr /home/davide/linux-socfpga-gsrd-17.1-cv-bin cp /home/davide/u-boot-socfpga/u-boot.img /home/davide/linux-socfpga-gsrd-17.1-cv-bin cd /home/davide/linux-socfpga-gsrd-17.1-cv-bin mv u-boot.img u-boot-cyclone5.img Now, writing again the image created on the SD card, the DevKit again gets stuck (with no surprise). The output is: U-Boot SPL 2013.01.01 (May 16 2018 - 13:45:39) BOARD : Altera SOCFPGA Cyclone V Board CLOCK: EOSC1 clock 25000 KHz CLOCK: EOSC2 clock 25000 KHz CLOCK: F2S_SDR_REF clock 0 KHz CLOCK: F2S_PER_REF clock 0 KHz CLOCK: MPU clock 925 MHz CLOCK: DDR clock 400 MHz CLOCK: UART clock 100000 KHz CLOCK: MMC clock 50000 KHz CLOCK: QSPI clock 370000 KHz RESET: COLD INFO : Watchdog enabled SDRAM: Initializing MMR registers SDRAM: Calibrating PHY SEQ.C: Preparing to start memory calibration SEQ.C: CALIBRATION PASSED SDRAM: 1024 MiB SDRAM: Initializing SDRAM ECC SDRAM: ECC initialized successfully with 1588 ms SDRAM: ECC Enabled ALTERA DWMMC: 0 U-Boot 2013.01.01-00138-g239ae4d (May 22 2018 - 16:25:58) CPU : Altera SOCFPGA Platform BOARD : Altera SOCFPGA Cyclone V Board I2C: ready DRAM: 1 GiB MMC: ALTERA DWMMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: mii0 Hit any key to stop autoboot: 0 reading u-boot.scr 128 bytes read in 3 ms (41 KiB/s)# # Executing script at 02000000 Wrong image format for "source" command reading zImage 4376720 bytes read in 202 ms (20.7 MiB/s) reading socfpga.dtb 24490 bytes read in 6 ms (3.9 MiB/s)# # Flattened Device Tree blob at 00000100 Booting using the fdt blob at 0x00000100 Loading Device Tree to 03ff7000, end 03ffffa9 ... OK Starting kernel ...- NOTE: since I work with Virtualbox, Ubuntu cannot see the SD card reader, so I transfer the image created to a shared folder with the host PC operating windows. Then I burn the SDcard with the Win32DiskImager program. When I use this program with the SDcard image delivered with the kit, it works fine, so I guess the problem doesn’t sits in this step.
