10 years ago
Cyclone V SE Preloader & u-boot
I'm trying to bring up a Cyclone V (5CSEBA2U19C8) on a custom board. The problem is, that i can't boot the u-boot.img. Here's my output:
U-Boot SPL 2013.01.01 (Jul 08 2016 - 17:26:30)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 20000 KHz
CLOCK: EOSC2 clock 20000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 600 MHz
CLOCK: DDR clock 300 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 5000 KHz
CLOCK: QSPI clock 2343 KHz
RESET: WARM
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
reading u-boot.img
Bad image with mismatched CRC
# ## ERROR# ## Please RESET the board# ##
I followed the GRSD for Quartus 14.1, my tools are
- Quartus 14.1 Build 186
- QSys 14.1 Build 186
- BSP Editor Build 186
The memory device is a Micron mt41j128m16jt-125 (http://192.168.1.106/part-db/show_part_info.php?pid=62) which is available in the HPS configurator (I used this configuration)
I also made a simple DDR3 test which looks like this:
# define CONFIG_SYS_DRAM_TEST
# if defined(CONFIG_SYS_DRAM_TEST)
# define CONFIG_SYS_MEMTEST_START 0x01000000
# define CONFIG_SYS_MEMTEST_END 0x02000000
int testdram (void)
    uint *pstart = (uint *) CONFIG_SYS_MEMTEST_START;
    uint *pend = (uint *) CONFIG_SYS_MEMTEST_END;
    uint *p;
    printf ("SDRAM test phase 1:\n");
    for (p = pstart; p < pend; p++)
        *p = 0xaaaa;
    for (p = pstart; p < pend; p++) {
        if (*p != 0xaaaa) {
            printf ("SDRAM test fails at: %08x\n", (uint) p);
            return 1;
    printf ("SDRAM test phase 2:\n");
        *p = 0x5555;
        if (*p != 0x5555) {
            return 1;
    printf ("SDRAM test passed.\n");
    return 0;
# endif
The test returend no errors. I also tried different u-boot.img files (prebuilts from SoCrates Eval Board and also from SoCKit). Of course I also build my own, which all had the same result.
Disabling the Checksum-Flag in the bsp-editor also had no effect.
Any ideas? It seems nobody else is having this problem. Am I missing something?
    If it helps, i compiled the preloader with debug output. Here's the output:
    U-Boot SPL 2013.01.01 (Jul 11 2016 - 10:46:04)
    RESET: WARM
    Configuring CTRLCFG
       Write - Address 0xffc25000 Data 0x000a8042
       Read and verify...correct!
    Configuring DRAMTIMING1
       Write - Address 0xffc25004 Data 0x3138ce06
    Configuring DRAMTIMING2
       Write - Address 0xffc25008 Data 0x0aaaa925
    Configuring DRAMTIMING3
       Write - Address 0xffc2500c Data 0x00221eb3
    Configuring DRAMTIMING4
       Write - Address 0xffc25010 Data 0x00000e00
    Configuring LOWPWRTIMING
       Write - Address 0xffc25014 Data 0x00080000
    Configuring DRAMADDRW
    workaround rows - memsize 4294967296
    workaround rows - cs        1
    workaround rows - width     8
    workaround rows - rows      14
    workaround rows - banks     3
    workaround rows - cols      10
    rows workaround - term1 4294967296
    rows workaround - term2 524288
    rows workaround - bits 1
    rows workaround - ilog2 19, 524288
       Write - Address 0xffc2502c Data 0x00000e6a
    Configuring DRAMIFWIDTH
       Write - Address 0xffc25030 Data 0x00000010
    Configuring DRAMDEVWIDTH
       Write - Address 0xffc25034 Data 0x00000008
    Configuring LOWPWREQ
       Write - Address 0xffc25054 Data 0x00000030
    Configuring DRAMINTR
       Write - Address 0xffc2503c Data 0x00000000
    Configuring STATICCFG
       Write - Address 0xffc2505c Data 0x00000002
    Configuring CTRLWIDTH
       Write - Address 0xffc25060 Data 0x00000001
    Configuring PORTCFG
       Write - Address 0xffc2507c Data 0x0000003f
    Configuring FIFOCFG
       Write - Address 0xffc25088 Data 0x00000000
    Configuring MPPRIORITY
       Write - Address 0xffc250ac Data 0x3ffd1088
    Configuring MPWEIGHT_MPWEIGHT_0
       Write - Address 0xffc250b0 Data 0x21084210
    Configuring MPWEIGHT_MPWEIGHT_1
       Write - Address 0xffc250b4 Data 0x8081ef84
    Configuring MPWEIGHT_MPWEIGHT_2
       Write - Address 0xffc250b8 Data 0x00000000
    Configuring MPWEIGHT_MPWEIGHT_3
       Write - Address 0xffc250bc Data 0x0000f800
    Configuring MPPACING_MPPACING_0
       Write - Address 0xffc250c0 Data 0x20820820
    Configuring MPPACING_MPPACING_1
       Write - Address 0xffc250c4 Data 0x08208208
    Configuring MPPACING_MPPACING_2
       Write - Address 0xffc250c8 Data 0x41041041
    Configuring MPPACING_MPPACING_3
       Write - Address 0xffc250cc Data 0x00410410
    Configuring MPTHRESHOLDRST_MPTHRESHOLDRST_0
       Write - Address 0xffc250d0 Data 0x01010101
    Configuring MPTHRESHOLDRST_MPTHRESHOLDRST_1
       Write - Address 0xffc250d4 Data 0x01010101
    Configuring MPTHRESHOLDRST_MPTHRESHOLDRST_2
       Write - Address 0xffc250d8 Data 0x00000101
    Configuring PHYCTRL_PHYCTRL_0
       Write - Address 0xffc25150 Data 0x00000200
    Configuring CPORTWIDTH
       Write - Address 0xffc25064 Data 0x00044555
       Read value without verify 0x00044fff
    Configuring CPORTWMAP
       Write - Address 0xffc25068 Data 0x2c011000
       Read value without verify 0x2c03ffff
    Configuring CPORTRMAP
       Write - Address 0xffc2506c Data 0x00b00088
       Read value without verify 0x00b3ffff
    Configuring RFIFOCMAP
       Write - Address 0xffc25070 Data 0x00760210
       Read value without verify 0x0076ffff
    Configuring WFIFOCMAP
       Write - Address 0xffc25074 Data 0x00980543
       Read value without verify 0x0098ffff
    Configuring CPORTRDWR
       Write - Address 0xffc25078 Data 0x0005a56a
       Read value without verify 0x0005afff
    Configuring DRAMODT
       Write - Address 0xffc25018 Data 0x00000001
    Configuring FPGAPORTRST
    Configuring STATICCFG_
       Write - Address 0xffc2505c Data 0x0000000a
       Read value without verify 0x00000002
    sdram_calculate_memory returns 268435456
    sdram set rule start 0, 0
    sdram set rule end   fff, 0
    sdram set rule end   ff, 268435456
    SDRAM Prot rule, default 3ff
    Rule 0, rules ...
        sdram start 0
        sdram end   fff00000
        low prot id 0, hi prot id 0
        portmask 0
        security 0
        result 0
        valid 0
    Rule 1, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 2, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 3, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 4, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 5, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 6, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 7, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 8, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 11, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 14, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    Rule 19, rules ...
        sdram start 0
        sdram end   fff00000
        portmask 0
        security 0
        result 0
        valid 0
    SDRAM: 256 MiB
    Setup interrupt controller... IRQ SP at 0x00000000 with size 0x00000400
    boot device - 3
    ALTERA DWMMC: 0
    Buswidth = 1, clock: 0
    Buswidth = 1, clock: 400000
    altera_dwmci_clksel: drvsel 3 smplsel 0
    altera_dwmci_clksel: SYSMGR_SDMMCGRP_CTRL_REG = 0x3
    Sending CMD0
    Sending CMD8
    Sending CMD55
    Sending CMD41
    Sending CMD55
    Sending CMD41
    Sending CMD2
    Sending CMD3
    Sending CMD9
    Sending CMD13
    Sending CMD7
    Sending CMD55
    Sending CMD51
    Sending CMD6
    Sending CMD6
    Sending CMD55
    Sending CMD6
    Buswidth = 4, clock: 400000
    Buswidth = 4, clock: 5000000
    Sending CMD16
    Sending CMD17
    boot mode - FAT
    Sending CMD16
    Sending CMD17
    Sending CMD16
    Sending CMD17
    reading u-boot.img
    Sending CMD16
    Sending CMD17
    VFAT Support enabled
    FAT16, fat_sect: 16, fatlength: 256
    Rootdir begins at cluster: 0, sector: 528, offset: 42000
    Data begins at: 528
    Sector size: 512, cluster size: 16
    FAT read sect=528, clust_size=16, DIRENTSPERBLOCK=16
    Sending CMD16
    Sending CMD18
    Sending CMD12
    Rootvfatname: |zimage|
    RootMismatch: |zimage|zimage|
    RootMismatch: |zimage||
    Rootvfatname: |u-boot.scr|
    RootMismatch: |u-boot.scr|u-boot.scr|
    RootMismatch: |u-boot.scr||
    Rootvfatname: |socfpga.dtb|
    RootMismatch: |socfpga.dtb|socfpga.dtb|
    RootMismatch: |socfpga.dtb||
    Rootvfatname: |system volume information|
    RootMismatch: |system~1|system volume information|
    RootMismatch: |system~1||
    Rootvfatname: |u-boot.img|
    RootName: u-boot.img, start: 0x527, size:  0x3f110
    Filesize: 258320 bytes
    64 bytes
    gc - clustnum: 1319, startsect: 21632
    Sending CMD16
    Sending CMD17
    Size: 258320, got: 64
    spl: payload image: U-Boot 2013.01.01 for socfpga bo&#9618;&#9618;neu|I&#9618;>&#9618;&#9618;&#9618;&#9618;z&#9618;&#9618;.{&#9618;&#9618;&#9618;&#9618;|&#9618;U;&#9618;/&&#9618;_&#9618;&#9618;P&#9618;&#9618;&#9618;&#9618;&#9618;u&#9618;&#9618;&#9618;&#9618;$&#9618;&#9618;&#9618;w&#9618;ng~&#9618;&#9618;W&#9618;
    Any ideas where the garbage at the bottom is coming from (It's much longer but i had to short it to fit this message, complete file is attached)? I don't get this without the debug flag set, I'm still digging...
    You can use the debugger help to read back the u-boot.img at SDRAM.
    Then you can compared whether any different with the file content.
    This can eliminate whether the DDR issue or the u-boot.img itself.
    Thank you very much for your input.
    I loaded the u-boot.img with the "restore" command to the DDR3 and after lots of experiments, i found out that I had to to adjust the DDR3 Ram settings in Qsys. Strangly, the preconfigured settings from Quartus do not match the datasheet for all parameters.
    The board is now up and running.
    Hi all -
    To revive a still-warm topic, I had a question about my first attempts at compiling and using the preloader and u-boot. I see the results here indicate that previous people have gotten further than me on the same board. My board is a 5CSEMA4U23 on the DE0-Nano-SoC kit and I want to be able to do some simple HPS clocking exercises. I have done the following:
    1. Loaded the GHRD in Quartus Prime Std. 16.1 and compiled
    2. Generated a .rbf binary file from Quartus
    3. Used the EDS shell to access bsp-editor and create and subsequently compile both the preloader-mkpimage.bin and u-boot.img files
    4. Placed both above files on the SDcard (using alt-boot-disk utility in EDS for the preloader) and added the system .rbf and *.dtb files to the SDcard
    5. Tried to boot up
    Assume that I have a (previously) working clean kernel of Linux which can be acquired from Terasic (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=205&no=941&partno=4) and that initial boot of the Linux fs was successful. Assume also I am interacting via putty serial to my board.
    I did these steps following the instructions for the Arrow SoC kit dictated by Kris Chaplin at Altera (https://www.youtube.com/watch?v=vs7pvefsbrm) but I get no data/boot when I run the new SD setup. What is missing? Thanks if you can lend any insight. I did not change any settings on the project from the GHRD, so I imagine the issue is simply something missing or incorrect with the preloader or the u-boot step. Since I can't even get an output from my device over serial maybe it is the preloader.. stumped.
    UPDATE:
    The issue seemed to be fixed by changing how I generated a .rbf output. Rather than manually creating a compressed *.rbf file from the <File -- Convert Programming> , I switched to auto-generating the *.rbf at compilation-time. After doing that my kernel booted fully. Sorry I don't have better root-cause results to share.
    There is a MSEL setting on board that you need to ensure that is correlate with the type of RBF generated.
    In other word, there is different MSEL setting for compressed and uncompressed RBF.
    You might want to take a look at FPGA Manager section documentation for more info.
