RTL_One
7 years agoCyclone V - VCCBAT voltage if not using volatile key (3.3V?)
I'm not using security volatile key and the Cyclone V pin connection guidelines say to connect VCCBAT to 1.5V, 2.5V, or 3.0V in order to exit POR. However, the Cyclone V datasheet (table 2) lists the...
AnandRaj_S_Intel
7 years agoHi,
we cannot guarantee on the performance and reliability of the device if you operate the devices above the maximum recommenced operating rating.
VCCBAT should be powered with voltage range as listed in the device datasheet.
However we can use the regulator.
Regards.
Anand
RTL_One
7 years agoThanks Anand, I have added a 2.5V regulator in accordance with the guidlines.
