9 years agoCyclone IV : boot nios from epcs
Dear all, I'm trying to run the nios directly from the flash (epcs16) on startup, but even if I apply step by step instructions on different files given by Altera, I never succeeded (the fpga w...
9 years agoHi,
Thanks for you answer. When I programmed the FPGA with a .pof or .jic file containing only the SOF, the FPGA configuration worked. Then, I added the nios code to the POF and the FPGA also worked. I'm going to try with the mem_ini_generate, and I'll set the generated hex file to the absolute address + 1 after the FPGA bitstream. Thank you
