9 years agoCyclone IV : boot nios from epcs
Dear all, I'm trying to run the nios directly from the flash (epcs16) on startup, but even if I apply step by step instructions on different files given by Altera, I never succeeded (the fpga w...
9 years agoFor the software configuration, can you try the mem_init_generate tool instead of sof2flash or elf2flash tool?
Any more description when you say it never works? If you programmed a JIC file containing only SOF, does the FPGA configuration works?
