10 years agoCyclone 5 pcie example project failure
Hi all, I'm new in altera world. My first board is cyclone 5 soc development board. I'm interested in pcie applications. From rocket board side, I found an example project but I couldn't compile i...
9 years agoUnfortunately, I am not really sure what could be the root cause of your issue. I have a slightly different setup (Quartus 16.0 lite version, Windows 10) - from the design downloaded the link below:
https://releases.rocketboards.org/release/2015.10/pcie-ed/hw/ I manage to open Qsys and run "Generate HDL.." successfully for both the full design and the simple design (no modification was done on either .qsys file). I chose the HDL design files as "Verilog" and Simulation Model as "None". Just to confirm, you did install Quartus in its default directory right?
