20 years agoCustom Boot Loading
Boot-Loader Application Notes Search words: boot, boot-loader, boot loader, boot loading, boot-loading, boot application (This technique of boot-loading was obtained from www.niosforum.com, search ...
19 years agoYou don't need another flash device. You are not running program directly on EPCS. You usually load from EPCS to some other memory and run. So you can run your flash writing program from onchip memory or other external memory.
If you will run uClinux, I posted some guide on the wiki, http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/flashprogrammer)
