14 years agoCreating mtd partitions within a single cfi-flash
Hello folks,
i'am trying to create multiple partitions within my single (4 MB) cfi-flash. These partitions should be mountable from uCLinux using jffs2. The flash section within my dts-file looks like this:
cfi_flash: flash@0x400000 {
compatible = "ALTR,cfi_flash-11.1", "cfi-flash";
reg = < 0x00400000 0x00400000 >;
bank-width = < 2 >;
device-width = < 1 >;
# address-cells = < 1 >;
# size-cells = < 1 >;
part_0@0 {
reg = < 0x00000000 0x00200000 >;
}; //end part_0@0
part_1@200000 {
reg = < 0x00200000 0x00200000 >;
}; //end part_1@200000
}; //end flash@0x400000 (cfi_flash)
But something must be wrong within my kernel-config. Because uCLinux detects only the cfi-flash device but not the partitions. I'am only able to mount the whole flash but not the different partitions. cat /proc/mtd displays: dev: size erasesize name mtd0: 00400000 00010000 "400000.flash" Please take a look at my kernel config.... Thank you so much.1 Reply
No one out there who uses flash-partitions?
