14 years agoCreating Memory device for Nios II processor
Hello, I want to transfer data from my custom component to the processor. Ideally it would be possible to access the data using pointer. Normally I would have to use IORD and IOWR macros to cir...
14 years agoWell I did that for purpose. Getting into the wrong area using a pointer is quite easy. Plus a DMA will give interrupt when data is ready, so You won't get the same result by reading the same value over and over again.
