15 years agoCreating a hex-file
It cannot be that hard: I have a nios2 project (including onchip_ram with "Enable non-default initialization file" checked) that can be compiled to an elf-file. But i don't get any hex-file when...
15 years agoShouldn't the Eclipse tools be able to generate this automatically with just a
click of a button/check_box? I have the same issue and would rather not create additional scripts unless necessary. Isn't all the information elf2hex needs passed with the SOPC system? In the worst case I can add a line to some edit box in the NIOS II eclipse project properties dialog. Or specifically what is the Altera recommended/approved method for performing this seemingly very common task. Thoughts? Thanks, Cos
