15 years agoCrash and semaphores
Hi, when I make three tasks synchronized by semaphores (the tasks do nothing, they only make a Post and then a Pend to pass the control each other), after a number of iterations (this number i...
15 years agoYes, as long as you do that in every thread that uses the standard output, and that you use the same semaphore on each, obviously.
I re-read your code and I'm wondering something... where do you post your semaphore sem_sync0 ? What are you trying to achieve in this code?
