16 years agocount_binary example -- fatal error couldn't allocate heap?
Hi, Did anyone see this error before when you try to build the count_binary example? I have a NEEK and try the count_binary. I'm using the ptf from the NEEK example. Thx **** Build of configu...
16 years agoTry the recommendation given at the following link:
http://www.cygwin.com/cygwin-ug-net/setup-maxmem.html In particular, try compiling and running the application given at the end of the recommendation. Here are the results that I see on my WinXP-64 machine with 8GB of RAM...compiled and ran from within a Nios II Command Shell.$ cat ./max_mem.c
main()
unsigned int bit=0x40000000, sum=0;
char *x;
while (bit > 4096)
x = malloc(bit);
if (x)
sum += bit;
bit >>= 1;
printf("%08x bytes (%.1fMb)\n", sum, sum/1024.0/1024.0);
return 0;
/cygdrive/c/Downloads
$ gcc max_mem.c -o max_mem.exe
$ ./max_mem.exe
5fffe000 bytes (1536.0Mb)Also, if you have a Logitech Quickcam, disable the driver for it and see if that makes a difference. My impression is that this is a Cygwin/Logitech issue, not an Altera/IDE/EDS issue. Cheers, - slacker
