16 years agocount_binary example -- fatal error couldn't allocate heap?
Hi, Did anyone see this error before when you try to build the count_binary example? I have a NEEK and try the count_binary. I'm using the ptf from the NEEK example. Thx **** Build of configu...
16 years agoBased on your reply. Here are some questions:
1) Is the other computer where it works a Vista 32 machine? 2) Are you using the old IDE? Are you able to use the new Software Build Tools for Eclipse? Suggestions: 1) If you really are using Nios II IDE, try the Software Build Tools for Eclipse instead. 2) Quit the GUI, remove the workspace, and re-create the count_binary project. 3) Try hello_world to see if it works. 4) If you are comfortable with the idea, try temporarily disabling your McAfee. The account I have says that McAfee version ~8.0 was present when the problem happened. The solution was to upgrade to McAfee version ~8.5. This report was a while ago, so I suspect you are long past version 8.0 by now. -edj
