14 years agoCould not read 8 bit data from custom ram
Hi every body! I'm a newbie in SOPC system design. I'm trying to create a custom ip, which has an internal RAM (declare as an array) and contacts with NIOS via Avalon MM bus. I'm using D...
14 years agothe availability of signals is dependant on the setup and wait settings in your hw.tcl file. having address available early is entirely plausible if you specify the behaviour in your hw.tcl file.
