14 years agoCould not read 8 bit data from custom ram
Hi every body! I'm a newbie in SOPC system design. I'm trying to create a custom ip, which has an internal RAM (declare as an array) and contacts with NIOS via Avalon MM bus. I'm using D...
14 years agoi believe your error is that there should be a read wait state. just as an fyi, there is no reason to use the read signal, you could have just always assigned readdata to the ram[address].
