15 years ago
component creation bug? (TOP_LEVEL_MODULE not specified)
Today I created a component in the SOPC Builder 11.0
When I created the component, I could add it without errors to my comfiguration, and generate the system. but when I would open my configuration, it says that the TOP_LEVEL_MODULE is not specified. After some trying I found out that the problem seems to lay in the following line in the .tcl file:
set_module_property STATIC_TOP_LEVEL_MODULE_NAME ""
This line is automatically generated. When I removed it, there was no problem with the component, but with the line like this in the .tcl file, I get the TOP_LEVEL_MODULE error. My solution was to add the top level module name between the quotation marks. It is something that I had to do by hand.
Is this a (known) bug, or maybe some setting or step that I missed?
    today I've created another component, but here I don't get any errors. This new component has only one module, no files included, that's a difference compared to the other part where there is one module with serveral included files (with sub-modules). I will send the service request next week.
    Any solution to this. I recently moved from Q10.1 to 11. None of my custom components will now work under either Q_Sys or SOPC_builder. They all fail with the same module not found error.
    A bit of digging...
    the quartus_map command runs fine and creates the following XML file
    <?xml version="1.0" encoding="ISO-8859-1" ?>
    <QUARTUS_MAP_OUTPUT>
    <QUARTUS version="Version 11.0 Build 157 04/27/2011 SJ Full Version" platform="[H[2J"/>
    <FILE name="keypad.vhd" path="/usr/quartus/ngunton/ip/keypad/" language="VHDL" languageversion="VHDL_1993">
    <MODULE name="keypad">
    <LIBRARIES>
    <LIBRARY name="ieee.std_logic_1164.all"/>
    <LIBRARY name="ieee.numeric_std.all"/>
    <LIBRARY name="std.standard.all"/>
    </LIBRARIES>
    <PORTS>
    <PORT name="sys_clk" direction="input" type="std_logic"/>
    <PORT name="resetn" direction="input" type="std_logic"/>
    <PORT name="row" direction="input" type="std_logic_vector" rangeleft="3" rangeright="0"/>
    <PORT name="col" direction="output" type="std_logic_vector" rangeleft="3" rangeright="0"/>
    <PORT name="shift" direction="output" type="std_logic_vector" rangeleft="31" rangeright="0"/>
    </PORTS>
    </MODULE>
    </FILE>
    </QUARTUS_MAP_OUTPUT>
    The messages from the create component wizard then read:
    Debug: Debug: Exception thrown while parsing XML from analyser
    Error: Error: No modules found when analyzing /usr/quartus/ngunton/ip/keypad/keypad.vhd.
    No amount of editing the _hw.tcl file has yet provided a solution.
    This problem occurs with both components consisting of a single file and of multiple files.
    Solution is in /etc/issue, mine was null. The posts on quartus_map seg faulting in Quartus 10 led me to the problem. I was initially misled as qenv.sh, called by quartus_map sets PLATFORM from uname and PLATFORM in the xml file generated by quartus_map contained non-printing garbage. Why it doesn't stick with uname...
    Trying to parse /etc/issue is completely fubar.
    They might as well try to parse /etc/motd :-)
