15 years ago
Compilling Linux with MMU on NIOS
I am compiling Linux on DE0 dev board and at the end of compilation errors appears:
CC lib/rwsem-spinlock.o
CC lib/sha1.o
CC lib/show_mem.o
CC lib/string.o
CC lib/vsprintf.o
AR lib/lib.a
LD arch/nios2/lib/built-in.o
CC arch/nios2/lib/libgcc.o
In file included from /home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c:13:
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/longlong.h:1237:2: warning:# warning "Default c-implementation of umul_ppm"
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/longlong.h:1264:2: warning:# warning "Default c-implementation of __umulsidi3"
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/longlong.h:1327:2: warning:# warning "Using count_leading_zeroes in C"
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c: In function '__ashldi3':
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c:52: warning: ISO C90 forbids mixed declarations and code
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c: In function '__ashrdi3':
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c:78: warning: ISO C90 forbids mixed declarations and code
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c: In function '__lshrdi3':
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c:105: warning: ISO C90 forbids mixed declarations and code
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c: In function '__udivmoddi4':
/home/darka/nios2-linux/linux-2.6/arch/nios2/lib/libgcc.c:351: warning: ISO C90 forbids mixed declarations and code
CC arch/nios2/lib/memcpy.o
CC arch/nios2/lib/string.o
AR arch/nios2/lib/lib.a
LD vmlinux.o
MODPOST vmlinux.o
GEN .version
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
/home/darka/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:173: ignoring invalid character `#' in expression
/home/darka/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:173: syntax error
make[2]: *** [.tmp_vmlinux1] Error 1
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/darka/nios2-linux/linux-2.6'
make: *** [linux] Error 1
[root@localhost uClinux-dist]#
Is there anybody whose got this same problem and know how to solve it ?
    Are you using QSys and sopc-create-header-files? I just noticed that it creates macros like# define KERNEL_REGION_BASE 0xc0000000L where it didn't used to put an L and looks like that doesn't work in the linker script and gives that error.
