20 years ago
Compact Flash Card
Hi ecos community,
I have a Nios dev board (Stratix edition) running an eCos application that logs data onto a Compact Flash card.
My application runs well, but I am trying to improve it in the way it deals with the Compact Flash card.
I would like my application to be able to get info on the CF card, ie card size, card maker, free space etc. I suspect the CF driver does not support this at present, but if it does I would like to know how.
Also, the CF driver supports interrupt driven card insertion functionality for card initialization, but on my board this does not work, as far as I can tell no interrupt is generated when a card is inserted. If anyone has experience in this area I would like to hear about it.
More detail follows...
From the API the following code should allow access to CF info:
error = cyg_io_lookup("/dev/cfa/1",&cf_handle); // get handle to CF
error = cyg_io_get_config(&cf_handle,0,xbuf,&len);
but the function alt_avalon_cf_get_config in altera_avalon_cf.c is just an empty stub, however the line of execution never appears to reach this code.
Is there anyone else out there using CF cards?
Peter
    There was a mistake in the second line of code, the correct code is below:
    error = cyg_io_get_config(cf_handle,0,xbuf,&len); // call for info, if any
    The following code fragments are a first attempt at providing access to CF information. The alt_avalon_cf_get_config stub is filled out and eCos cleaned and rebuilt.
    // fill out stub in altera_avalon_cf.c
    // Altera Avalon compact flash driver
    alt_avalon_cf_get_config(disk_channel *chan,
    cyg_uint32 key,
    const void *xbuf, //cyg_disk_info_t;
    cyg_uint32 *len)
    cyg_disk_info_t *info = chan->info; // info is a pointer
    cyg_disk_info_t *buf = (cyg_disk_info_t *) xbuf;
    cyg_disk_identify_t *ident = &chan->info->ident;
    Cyg_ErrNo res = ENOERR;
    D("alt_avalon_cf_get_config\n");
    if (!chan->init)
    return -EINVAL;
    if (*len < sizeof(cyg_disk_info_t))
    return -EINVAL;
    *buf = *info;
    *len = sizeof(cyg_disk_info_t);
    //D((" serial = &#39;%s&#39;\n", ident->serial));
    //D((" firmware rev = &#39;%s&#39;\n", ident->firmware_rev));
    D(" model num = &#39;%s&#39;\n", ident->model_num);
    D(" block_size = %d\n", info->block_size);
    D(" blocks_num = %d\n", info->blocks_num);
    return res;
    Here is a code fragment to access the info. In this case
    the block size, number of blocks and CF model string.
    // code to access CF info
    // use API call &#39;cyg_io_get_config&#39;
    // information on the CF card
    cyg_disk_info_t cf_info;
    char cf_model[20];
    // later on...
    { // get CF card info
    cyg_io_handle_t cf_handle;
    void *xbuf = (void *)&cf_info; //cyg_disk_info_t
    Cyg_ErrNo error;
    cyg_uint32 len = sizeof(cyg_disk_info_t);
    error = cyg_io_lookup("/dev/cfa/1", &cf_handle);
    if(error!=0) printf("lookup error:%i\n",error);
    else
    printf("cf get_config error: %i %i\n",error,-EINVAL); // should get -EINVAL
    //cf_info_ptr = *(cyg_disk_info_t *)xbuf;
    // get useful info
    block_size = cf_info.block_size;
    blocks_num = cf_info.blocks_num;
    strncpy(cf_model,cf_info.ident.model_num,16);
    printf("block size:%i num_blocks:%i %s\n"
    ,cf_info.block_size,cf_info.blocks_num,cf_model);
    Looks like I get to answer my own questions.
