21 years agocommunicating between UART and Memory dev ?
I am having a onchip memory on which i wish to write through input device like uart and futhur what ever i have written i want it to be looped back i.e then i want to read the contents from the memor...
14 years agoYou can do that only if you run your application with the debugger and use the host filesystem software component.
