20 years agochar takes 4 bytes?
char test_char=-5;
printf("test_char %x,%x,%x\n",test_char,(char)test_char,(unsign char)test_char); We expect the output was: >test_char fb,fb,fb but we got : >test_char fffffffb,fffffffb,fb why dose "char" variable have 4 bytes?4 Replies
--- Quote Start --- originally posted by mountain8848@Nov 9 2005, 10:10 AMchar test_char=-5; printf("test_char %x,%x,%x\n",test_char,(char)test_char,(unsign char)test_char);we expect the output was:
>test_char fb,fb,fb
but we got :
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10869)</div> --- Quote End --- The char is converted to int by the printf. since 0xfb is a negative number, the resulting value is sign extended to 4 bytes, that is, 0xf...ffb bye Paolo
Hi, paolo
Look the below codes, we got the result what we not expected, either.
the result: >they are not equal >test_char is not 0xfb what should we do? As we should modify lots of codes what these error.char test_char=-5; unsigned char good=0xfb; if(test_char==good){ printf("they are equal\n"); }else{ printf("they are not equal\n"); } if(test_char==0xfb){ printf("test_char is 0xfb\n"); }else{ printf("test_char is not 0xfb\n"); } - Altera_Forum
Mountain,
Mask it with 0xff, this will "cut" off the upper 24 bits. if((test_char&0xff)==good) Doug - Altera_Forum
Hi All,
> what should we do? Start by writing good code ... pick your data type and stick with it. The result of relational and equality operators is of type int when the operands are integral types ... so, char and unsigned char are promoted to type int (the range of both can be represented by an int) ... and the sign is preserved (or "extended" into the higher-order bits). Basically, if (for whatever reason) bit 7 of your 8-bit data is not a sign bit, then don't treat it as such -- use unsigned char instead (and ditto for short and unsigned short) ... you'll save yourself some headaches and you can use:
with confidence. Regards, --Scottif(test_char==good)
