14 years agoCFI Flash software driver Support for 32-bits Flash
Hi, Does the CFI flash software driver support 32-bits flash? My QSYS system is having 32-bits ext flash. When I tried memory test from Eclipse template, it always fails to open the flash. It...
14 years agoI forgot to specify that the x16x16 support in nios2-flash-programmer and in the currently debugging x16x16 BUP are all for Intel algorithm devices (command set 1). No AMD command set (2) support for x16x16 is available at this time.
