14 years agoCFI Flash software driver Support for 32-bits Flash
Hi, Does the CFI flash software driver support 32-bits flash? My QSYS system is having 32-bits ext flash. When I tried memory test from Eclipse template, it always fails to open the flash. It...
14 years agoThat is the sort of thing it must do (I can't remember the command values!).
There is also likely to be a loop where it waits for a bit to change - indicating that the write/erase is complete. That code must wait for the bit to change in both the high and low halves of the word - so that both chips have finished.
