14 years agoCFI Flash software driver Support for 32-bits Flash
Hi, Does the CFI flash software driver support 32-bits flash? My QSYS system is having 32-bits ext flash. When I tried memory test from Eclipse template, it always fails to open the flash. It...
14 years agoIf your flash memory only supports 32bit accesses, you should leave byteenable signals unconnected.
addr[2] from the tristate bus should be connected to A0 pin on flash memory, addr[3] to flash A1, and so on. If your flash memory also supports 8 and 16bit modes, you may need to connect tristate addr[n] to flash A[n] because the flash memory itself uses byte addressing. Refer to flash datasheet
