9 years agoCan't stop debugging application
Hello, While debugging application I've met strange problem - I can't stop it. When I click on "STOP" button, several seconds later the following window appears: https://alteraforum.com/...
9 years agoRestarting Eclipse doesn't help, as application is still "hanging" ... and all attempts to run/debug new application fail.
So, the only solution - Power OFF/ON the Cyclon board, reprogram it, and then run NIOS application. Has anyone ever met the same problem ?
