16 years agoCan't simulate a multiprocessor on modelsim
Dear all,
i'm new to HW/SW modeling and verification. i've been trying to follow a tutorial to simulate a multiprocessor enviroment I don't have a board so i thought that it might be possible to run it on modelsim. I have done all the steps to create the model and i've build the software model on the ide. Then i opened a Nios II shell command and run vsim setup_sim.do then on the modelsim i follow these steps: "s" "w" "jtag_uart" run 800 us the simulation starts and i get this message: Note: Stratix II PLL locked to incoming clock # Time: 110 ns Iteration: 0 Instance: /test_bench/dut/the_pll/the_pll/altpll_component/stratixii_altpll/m1 # 2410 ns: ERROR: cpu1_test_bench/M_en is 'x' # ** Failure: VHDL STOP # Time: 2410 ns Iteration: 11 Process: /test_bench/dut/the_cpu1/the_cpu1_test_bench/#MERGED#line__795,760,704,686,649,613,595,577,521,465 File: C:/Projet_Nios_Modelsim/projet_nios_modelsim_multiprocessor/standard/cpu1_test_bench.vhd # Break in Architecture europa at C:/Projet_Nios_Modelsim/projet_nios_modelsim_multiprocessor/standard/cpu1_test_bench.vhd line 588 can anyone help me to find the solution ? Thank youNo RepliesBe the first to reply
