9 years agocan't generate nios II .sof file
hi everyone..i try to connect my program to the board but unfortunately this kind of error was popup "No Nios II target connection paths were located. Check connections and that a Nios II .sof ...
9 years agothanks forum_newbie for the answer..the pin already assigned correctly...but the problem still occur..where can i find the nios ii debug rest request because im really blur about that...and for your information i use nios II/e version because i dont have the license..is it this version of nios make the "elf process downloading failed" occur? and if i use nios II/f..is it the problem can solve?
