9 years agocan't generate nios II .sof file
hi everyone..i try to connect my program to the board but unfortunately this kind of error was popup "No Nios II target connection paths were located. Check connections and that a Nios II .sof ...
9 years agoIs your pins being assigned correctly especially you reset pin? The other thing you can check is the Nios II debug reset request. Is it connected to the jtag reset port?
