9 years agocan't generate nios II .sof file
hi everyone..i try to connect my program to the board but unfortunately this kind of error was popup "No Nios II target connection paths were located. Check connections and that a Nios II .sof ...
9 years agofirstly, sorry for the late reply and thanks for your answer forum_newbie...now i can generate the .sof file already..but im facing the new problem right now which is the ELF process downloading failed...what should i do to solve this problem?can you help me?because i already try a lot of solution to confront this problem by looking for previous forum but i still didnt get the solution..
