9 years agocan't generate nios II .sof file
hi everyone..i try to connect my program to the board but unfortunately this kind of error was popup "No Nios II target connection paths were located. Check connections and that a Nios II .sof ...
9 years agoFirstly, is your usb blaster working? Can check if the jtag connection is working at the Quartus II Programmer.
Secondly, have you successfully run full compilation in Quartus and downloaded the .sof file into your board?
