Grorel
8 years agoCan the Cyclone V SoC UART Controller be used as RS485 ?
I have a Cyclone V SoC running in my product with Linux on the ARM. I uses UART0 controller on the HPS pins for the linux console mounted on /dev/ttyS0. The UART1 controller signals are linked to t...
FawazJ_Altera
8 years agoYou are welcome Aurélien,
You still can use the Soft-core IPs from FPGA side. However, you might not be able to use the software driver of this IP on HPS. The software drivers of the soft-core IPs available in Platform designer were developed to support embedded Nios II system designs. You can access these IPs from HPS, and you need to develop your own driver/macro to function this IP.
Best Regards.
Fawaz,
