14 years agoCan not find file "altera_avalon_timer.h"
Hi Everybody, I have got the problem when finding the solution to measure performance of C program on NiosII. Here is the example code that I have followed an example in ...
14 years agoYou should add the timer to your timestamp_timer_settings in the BSP/system library:
SysLib/BSP -> Properties -> System Library -> Timestamp Timer This setting is 'none' by default
