15 years agoCan I use 8M sdram for nios2-mmu linux?
hello, I have a custom fpga board with a ep2c20 core, a 8M cfi flash chip, a 8M sdram chip, etc.I design a smallest nios2 sopc with just a sdram controller, uart jtag and nios2-mmu with dual port ...
15 years ago --- Quote Start --- Did You set the SDRAM address correctly? There are issues with that. --- Quote End --- Thanks very much for your tips, I should modify the nios.h of in the nios2/include/asm and then it works but I still have problem, see the result: ... pid_max: default: 4096 minimum: 301 Mount-cache hash table entries: 512 ������������������ ... I got lots of "????", what's wrong with me again? thanks!
