fwenb
7 years agoCan EPCQ16ASI8N completely replace EPCS16SI8N?
I used EPCQ16ASI8N to replace EPCS16SI8N, but I found out that I can't burn the program.I found in the datasheet that the structure of EPCS16SI8N is AS × 1, EPCQ16ASI8N has AS × 1 and AS × 4.The orde...
fwenb
7 years agoI use Quartus II to program the device. I see that there is a way to enable the Disable EPCS/EPCQ ID check option in guidance, but the software used is Quartus Prime. How do I use Quartus II to block ID checks?
Thank you for your help.
Tom
