20 years agocal_uart(with fifo) + NIOSserial.c
As we know, we need uart with fifo to enchance the performance. So we got the cal_uart from Altera, which should tested by ourselves because it is not provided officially by altera. Now we use...
20 years agoHi all,
here is some good news for those who want a better performance on UART, based on cal_uart. I could achieve a 1MBytes transfer at 115200 bps with no errors when "cat /dev/ttyS0 > /tmp/file&" is the only user task I run (Nios2\s at 72MHz). I get ~1% error on 1MBytes transfer when running several daemons at the same time. I did it with a 64 bytes FIFO and I had the same performances with a 1024 bytes FIFO. To do this I modified the VHDL file generated by cal_uart to change the rx irq conditions. The interrupt is requested when FIFO is 50% full or if bytes are present in buffer after a delay (so that even if FIFO never gets 50% full, bytes can be read). I still have some questions about this : - I don't know anything about the scripts that generate the VHDL from the SOPC builder .ptf file. Can someone tell me where I should add my code so that it is generated in the cal_uart component ? Is this in the em_uart.pl script ? Is there any documentation on how to use this kind of scripts ? For now I have to modify the VHDL file after generating the SOPC builder components, this is not very elegant (see below)... - To adjust performance, I can play with 3 parameters : FIFO size, FIFO level to request IRQ (50% full, 75% full....) and the timer delay. I tried with 64 bytes FIFO, 50% full and 7ms delay. Does anyone have an idea of the parameters commonly used in other FIFO'ed uarts ? If someone is interested, here is the small modifications to do to the uart_ext.vhd file generated when using a cal_uart at 115200 bauds, 8N1, RTSCTS enabled, baudrate divisor writeable, and a 64 bytes FIFO : At line 1288, replace signal tx_not_empty : STD_LOGIC;
signal tx_not_full : STD_LOGIC;
signal tx_overrun : STD_LOGIC;
signal tx_used : STD_LOGIC_VECTOR (5 DOWNTO 0); by signal tx_not_empty : STD_LOGIC;
signal rx_counter : STD_LOGIC_VECTOR (18 DOWNTO 0);
signal rx_fifo_timeout : STD_LOGIC; At line 1541, replace qualified_irq <= ((((((((((ie_dcts AND dcts_status_bit)) OR ((ie_any_error AND any_error))) OR ((ie_tx_shift_empty AND tx_shift_empty))) OR ((ie_tx_overrun AND tx_overrun))) OR ((ie_rx_overrun AND rx_overrun))) OR ((ie_break_detect AND break_detect))) OR ((ie_framing_error AND framing_error))) OR ((ie_parity_error AND parity_error))) OR ((ie_rx_char_ready AND x_not_empty))) OR ((ie_tx_ready AND tx_not_full)); by qualified_irq <= ((((((((((ie_dcts AND dcts_status_bit)) OR ((ie_any_error AND any_error))) OR ((ie_tx_shift_empty AND tx_shift_empty))) OR ((ie_tx_overrun AND tx_overrun))) OR ((ie_rx_overrun AND rx_overrun))) OR ((ie_break_detect AND break_detect))) OR ((ie_framing_error AND framing_error))) OR ((ie_parity_error AND parity_error))) OR ((ie_rx_char_ready AND (rx_used(5) OR rx_fifo_timeout )))) OR ((ie_tx_ready AND tx_not_full));
process (clk, reset_n)
begin
if reset_n = '0' then
rx_fifo_timeout <= '0';
rx_counter <= (others => '0');
elsif clk'event and clk = '1' then
if std_logic'(clk_en) = '1' then
if rx_counter(18) = '1' then
if rx_empty = '1' then
else
rx_fifo_timeout <= '1';
end if;
else
rx_counter <= rx_counter + 1;
end if;
end if;
end if;
end process; I hope someone can help me automate this :-) Any comments or help welcome. Regards Pierre-Olivier
