14 years agoCache Implmentation
Hi All, I'm working on a research project involving NiosII processor. We need to be able to control cache bypass signal. Can any of you guide me how to do that? I need to instantiate the Nios...
14 years ago --- Quote Start --- I am wondering why on chip memory is cached by nios2? Is on chip memory as fast as nios2? --- Quote End --- As Daixiwen said, Nios caches everything connected to its data and instruction masters. This is consistent, since in general you can have multi-master buses and your cpu would stall when another master is accessing the bus. Using cache also for onchip memory reduces the frequency of such a situation. Tightly coupled memory takes advantage of a dedicated port, so it doesn't need to be cached.
