14 years agoCache Implmentation
Hi All, I'm working on a research project involving NiosII processor. We need to be able to control cache bypass signal. Can any of you guide me how to do that? I need to instantiate the Nios...
14 years agoThe CPU caches everything that is connected to its data and instruction masters by default. You can either use uncached memory pointers in the software code to avoid the cache, or connect the on chip memories to tightly coupled masters, that will avoid the cache.
