15 years agoC2H is missing SOLVED
When I right click on a selected function in my source code in Eclipse the "Accelerate with the Nios II C2H Compiler" option is missing. What is wrong? Is there any way to enable this?
15 years ago --- Quote Start --- When you run the installer it will ask you what tools to install. If you want to use C2H make sure the legacy Nios II tools are installed. I think they are installed by default in 11.0 so you probably already have what you need installed. --- Quote End --- No, the Legacy tools has to be downloaded from here: <altera home page>/download/software/nios-ii At least I had to do that. Full installaton of 11.0 did not include that.
