15 years agoC2H is missing SOLVED
When I right click on a selected function in my source code in Eclipse the "Accelerate with the Nios II C2H Compiler" option is missing. What is wrong? Is there any way to enable this?
15 years agoWhen you run the installer it will ask you what tools to install. If you want to use C2H make sure the legacy Nios II tools are installed. I think they are installed by default in 11.0 so you probably already have what you need installed.
