15 years agoC2H is missing SOLVED
When I right click on a selected function in my source code in Eclipse the "Accelerate with the Nios II C2H Compiler" option is missing. What is wrong? Is there any way to enable this?
15 years ago --- Quote Start --- How to option C2H compiler and turn it on? My Nios II SBT for eclipse is 10.1 sp1, But I don't found the"Accelerate with the Nios II C2H Compiler". Thanks. --- Quote End --- You have to run the Legacy NIOS II IDE, not the NIOS II SBT for Eclipse. Also, I think you have to right-click on the function name in the source code. Hope this helps. In my case, I can find the "Accelerate with the Nios II C2H Compiler" option but it just does not work. Nothing happens when I click it. Please try and tell about your experience
