15 years agoC2H is missing SOLVED
When I right click on a selected function in my source code in Eclipse the "Accelerate with the Nios II C2H Compiler" option is missing. What is wrong? Is there any way to enable this?
15 years ago --- Quote Start --- So that others know you'll also have to install the legacy Nios II tools from the Altera installer. In 11.0 I believe this is enabled by default but you do have the option to turn it off. If you turn it off the installer will not install the IDE or C2H to your drive. --- Quote End --- How to option C2H compiler and turn it on? My Nios II SBT for eclipse is 10.1 sp1, But I don't found the"Accelerate with the Nios II C2H Compiler". Thanks.
