14 years agoC++ Nios Program
Hello, Can anyone point me to an example of actually building a Nios-II project with cpp? I have tried many ways and it always comes down to a build error. The problem seems to be related to the a...
14 years agoFirst of all you should rename as alt_main.cpp.
Then, if your .cpp contain functions which are supposed to be called from .c sources, you must declare them as extern "C"
