8 years agoC help with read/write to Qsys component
I am using the Data Pattern Generator/Checker IP in a Qsys file and trying to configure it via a NIOS. However, I am having some trouble. I am using IOWR_32DIRECT() and IORD_32DIRECT() to write and r...
8 years agoHi,
--- Quote Start --- Setting pattern to PRBS31… The value read from Generator is 8 The value read from Checker is 8 Enabling pattern generator… The value read from Checker is 0 The value read from Generator is 0 --- Quote End --- Maybe the eclipse project is corrupted, Delete and create a new project and check. Are you expecting output like below --- Quote Start --- Setting pattern to PRBS31… The value read from Generator is 2 The value read from Checker is 2 --- Quote End --- Are you trying to check the Enable bit? Then it's should have a value whose LSB bit 1.Example. --- Quote Start --- Enabling pattern generator… The value read from Checker is 2b The value read from Generator is d --- Quote End --- Let me know if this has helped resolve the issue you are facing or if you need any further assistance. https://www.alteraforum.com/forum/attachment.php?attachmentid=15472 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
