21 years agoC++ global objects
The NiosII linker fails to call constructors for static global objects.
A simple example: test.h:# include <math.h> const double PI = 3.14159265; class Circle { protected: double radius; public: Circle(double = 1.0); double calcval(); }; test.cxx:# include "test.h" Circle::Circle(double r) { radius = r; } double Circle::calcval(void) { return(PI * radius * radius); } testprog.cxx:# include <stdlib.h># include <stdio.h># include "test.h" static Circle circle_1(10); int main() { printf("The area of circle_1 is %f\n", circle_1.calcval()); exit (0); } This fails. Circle_1 will always be 0. Putting the declaration inside main works: int main() { Circle circle_1(10); printf("The area of circle_1 is %f\n", circle_1.calcval()); exit (0); } Have anyone else experienced this ? Is it a g++ or ld bug, or do there exist any magic compiler/linker flags that I'm missing ? (The example code works fine with gcc 3.4.1 on x86).4 Replies
Apparently there is something wrong with the linker script. I'm using the default linker script shipped with the Microtronix uClinux port (elf2flt.ld). Are there any linker script gurus here ?
Do you have the compiler option -mctors-in-init? You might also want the library -lsupc++
Thanks! Adding -mctors-in-init to LDFLAGS did the trick. Can't find this compiler option documented anywhere. Is it an arch specific option ?
It is a Nios II specific option, but I did not find anything about it in Altera's document.
