9 years agoC code syntax coloring in NIOS Eclipse editor
Hello, Here below how C source code appears in Eclipse editor. 2nd screenshot - the same code in Notepad++. Is there some option that allows highlight C/C++ syntax in Eclipse editor. Thanks...
9 years agoFinally I've get it colored. For this I needed to close/open the source file.
But initially, when I've created a new file and then pasted the source code from another file, the code appeared in BW. Probably a bug (insignificant nevertheless)
