10 years agoburn two max 10 in 2 hours, someone please tell me the power on/off secquence
burn two max 10 in 2 hours, someone please tell me the power on/off secquence of the altera fpga and jtag i use 5 years xilinx and recently i want to use altera i think may be my bad habits make...
10 years agoSo these board did work before and now they don't. Perhaps you could have said that before.
You have two likely causes: a) You are powering the device incorrectly. Check the voltages you are using for each different VCC bank (VCCINT, VCCIO etc.) and make sure they are the right voltages. Check every GND pin is connected. or b) You are doing something to the device, through the I/O that the MAX 10 doesn't like. If you're happy to put the schematics up here I will happily have a look. Cheers, Alex
