8 years agoBuilding the preloader from U-BOOT socfpga 2018.01 sources
I'm developing a bare metal application for a cyclone V FPGA. The application is loaded from QSPI flash into RAM by the preloader. I recently needed to try a new QSPI device. The U-BOOT 2013.01...
8 years agoHi,
I did enable UART output in the bsp-editor and the baud rate is correct. I have not checked the configuration pins yet. I will try debugging the preloader to see what happens. I'll post in this thread again when I get the debugger up and running. Best regards, Aldridge
